Пъврият Валидиран Готов Портал
DevNull
Здавейте . след много труд и мъки най-накрая успях . Незнам дали е първият но до сега не бях виждал друга готова система да е валидирана с w3. Системата е MkPortal . Имайте в предвид че дизайна съм го правил сам не е готов темплейт .
така ето и сайта
http://lafchebg.info
http://validator.w3.org/check?uri=http://lafchebg.info/index.php
може и да е първия може и да е последния незнам ....
Проблема беше отстранен . Сега вече е валиден !!!
валиден ....
Validation Output: 26 Errors
Line 315, Column > 80: XML Parsing Error: attributes construct error.
…sp;Анонимни<br /><b>1</b>  Видими:<br /> <a href="./forum/profile.php?mo…✉
Line 315, Column > 80: XML Parsing Error: Couldn't find end of Start Tag a line 315.
Line 315, Column > 80: XML Parsing Error: Opening and ending tag mismatch: td line 314 and a.
Line 316, Column 10: XML Parsing Error: Opening and ending tag mismatch: tr line 313 and td.
</td>✉
Line 317, Column 15: XML Parsing Error: Opening and ending tag mismatch: table line 307 and tr.
</tr>✉
Line 318, Column 16: XML Parsing Error: Opening and ending tag mismatch: td line 306 and table.
</table>✉
Line 319, Column 11: XML Parsing Error: Opening and ending tag mismatch: tr line 305 and td.
</td>✉
Line 320, Column 9: XML Parsing Error: Opening and ending tag mismatch: table line 303 and tr.
</tr>✉
Line 327, Column 17: XML Parsing Error: Opening and ending tag mismatch: td line 302 and table.
</table>✉
Line 328, Column 12: XML Parsing Error: Opening and ending tag mismatch: tr line 301 and td.
</td>✉
Line 329, Column 10: XML Parsing Error: Opening and ending tag mismatch: table line 290 and tr.
</tr>✉
Line 331, Column 11: XML Parsing Error: Opening and ending tag mismatch: td line 289 and table.
</table>✉
Line 332, Column 13: XML Parsing Error: Opening and ending tag mismatch: tr line 288 and td.
</td>✉
Line 333, Column 11: XML Parsing Error: Opening and ending tag mismatch: table line 116 and tr.
</tr>✉
Line 341, Column 8: XML Parsing Error: Opening and ending tag mismatch: td line 115 and table.
</table>✉
Line 351, Column 5: XML Parsing Error: Opening and ending tag mismatch: tr line 110 and td.
</td> ✉
Line 945, Column 12: XML Parsing Error: Opening and ending tag mismatch: table line 109 and tr.
</tr>✉
Line 946, Column 13: XML Parsing Error: Opening and ending tag mismatch: td line 108 and table.
</table>✉
Line 947, Column 8: XML Parsing Error: Opening and ending tag mismatch: tr line 107 and td.
</td>✉
Line 948, Column 6: XML Parsing Error: Opening and ending tag mismatch: table line 39 and tr.
</tr>✉
Line 954, Column 14: XML Parsing Error: Opening and ending tag mismatch: td line 37 and table.
</table>✉
Line 955, Column 9: XML Parsing Error: Opening and ending tag mismatch: tr line 36 and td.
</td>✉
Line 956, Column 7: XML Parsing Error: Opening and ending tag mismatch: table line 34 and tr.
</tr>✉
Line 957, Column 8: XML Parsing Error: Opening and ending tag mismatch: div line 33 and table.
</table>✉
Line 958, Column 6: XML Parsing Error: Opening and ending tag mismatch: body line 27 and div.
</div>✉
Line 968, Column 7: XML Parsing Error: Opening and ending tag mismatch: html line 5 and body.
</body>✉
stoqnski каза:
валиден ....
</td>✉
</tr>✉
</table>✉
</td>✉
</tr>✉
</table>✉
</td>✉
</tr>✉
</table>✉
</td>✉
</tr>✉
</table>✉
</td> ✉
</tr>✉
</table>✉
</td>✉
</tr>✉
</table>✉
</td>✉
</tr>✉
</table>✉
</div>✉
</body>✉
Сега пак показва че е валидан ко става един пат невалиден др валиден
незнам не ми го правеше тоя проблем а не съм барал нищо по кодовете .....
като влезна ми го дава щом съм логофф пак си е валиден незнам какво става ........
Мисля, че всичките портали са валидни. Ето ти php-fusion
http://validator.w3.org/check?uri=http://freedemo.freehostia.com
незнам но този Мкпортал не беше валиден докато не му оправих целия темплейт файл за индекса . незнам защо но ми прави проблем с валидацията при логин е грешен при логоут е верен това не мога да го проумея как става .......
miro91 каза:
stoqnski каза:
валиден ....
</td>✉
</tr>✉
</table>✉
</td>✉
</tr>✉
</table>✉
</td>✉
</tr>✉
</table>✉
</td>✉
</tr>✉
</table>✉
</td> ✉
</tr>✉
</table>✉
</td>✉
</tr>✉
</table>✉
</td>✉
</tr>✉
</table>✉
</div>✉
</body>✉
ако можете кажете ми как да го оправя това защото е дразнещо . винаги когато има някой логнат винаги ще прави този проблем .....
Линковете към потребителите на линия сигурно съдържат & и не се използва urlencode или & и зтова може би.
на мен нещо не ми го отваря
phpBB : Critical Error
Could not query database for theme info
DEBUG MODE
SQL Error : 1064 You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '' at line 3
